Mast length
E
Ed
I recentlyn purchased a 1984 Hunter 27... Of all the specifications listed on this site, I have not found out the exact mast height/length.. Can someone help me out here??/ Also , What would be the figure for bridge clearance??
Pete
mast height
Ed,according to the spec sheets here on HOW the mast height is 36'3". You can aways measure it using the halyard (run it up to mast top and be sure to try on a return line)mark the halyard and measure. Add water line to deck height (where you marked halyard) and add any height for the windex,antenna etc. Will give you you exact height.
