REPAIR DETAILS
ONE: FIND 2-2"X4"X58" STUDS, NAIL EM TOGETHER, 1- 2"X4"PC'S OF STUD, AND A CAR SIZZOR OR HYD. JACK, INSTALL THE LITTLE PC ON TOP END, TWO" SET NAILED STUD ON TOP OF JACK,WITH THE LITTLE PC. ON TOP(NAILED) REMOVE PRESSURE, FROM COMPRESSION POST, AND REMOVE COMPRESSION POST. tHREE: THE ROTTED AREA IS OFCOURSE ON THE BOTTOM END, YOU HAVE TO REMOVE THE TEAK COVERING VERY CAREFULLY, WITH A CHIZZEL, ONCE THE TEAK IS REMOVED,FOUR: CUT OFF THE BOTTEM END AT THE 9" TO THE BOTTOM OF THE WIRE SLOT OR TRENCH IN THE BEAM, GO TO HOME DEPOT AND LOOK FOR A NICE CLEAN(NO KNOTS) PC. OF TREATED 4"X4" POST A FOOT LONG IF YOU CAN FIND IT, FIVE:MARK THE CENTER OF THE 4X4 AND DRILL A 1"DIA. HOLE, 3" DEEP THROUGH THE COMPRESSION POST AND THE NEW 4X4, CUT THE POST SIDES (TWO OR FOUR,) SO THAT THE POST MEASURES 3&3/8" SQUATE, BY APPROX. 9&1/4" LONG, USE A PC OF 1"DIA. S/S TUBING TO CENTRALIZE THE ADDITION, THE SHAVE SIDES FOR EXACT FIT, SIDE DRILL, THE POSTS AND TUBE FOR ALIGNMENT, EPOXY THE JOINTS TOGETHER AND REINSTALL THE TEAK, MAKE SURE THE 1&1/2" SQ. WIRE TRENCH IS CLEAR, OD DEBRIS, AND RETURN YOUR REPAIRED POST INTO POSITION, AND REMOVE THE JACK AND TEMP POST. GOOD LUCK.
