mast hunter 31 1984
3
Hunter 31_83-87 -
does anyone know the manufacturer of the mast on a 1984 hunter 34. its the almost rectangle type. does anyone also know of a used one with shrouds , stays, spreaders, ect. and a used headsail for a furling system.
Grizz
Jan 13, 2006
179
Hunter 28.5 Park Ridge, IL
Bettin' Kenyon
But check the link to see what info the site divulges. Good luck w/ the search for used as a friend w/ a 30' 1980 Hunter is just now being re-masted after losing his mast, and the entire '07 sailing season, during his river trip to harbor last spring (something about the bridge not completely open or veering off course; either way, mast & bridge made contact). He put a national search effort into play for a used replacement, lost his season and finally caved in last fall and bought new. Hope you have better results. Good luck with your search efforts.
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Kenyon or Isomat
Both Kenyon & Isomat have been used on Hunter 31's and on 28.5's. They have different spreaders, different mast head, gosneck and exit sheave fittings, and slightly different moment of inertia and cross sections. You need to get everything from ONE source.
Feb 22, 2004
222
Hunter H340 Michigan City
Mine is ISOMAT
Mine has a label on the bottom of the mast near the cabin top that says Isomat.
