B331 specs here: SailboatData.com - BENETEAU 331 Sailboat. A method I use to obtain running rigging lengths and replace lines is to sew a messenger line to the end of your existing topping lift and cover with tape, pull the line through, remove the topping lift, measure it, then reverse the process with the new line.
I think you have hit the nail on the head! I have to do that anyway. Why just not do it and be dome with it. Otherwise I'll be adding many feet to make sure and it will cost be a lot more. Thanks!
