We unstepped the mast and I've been labeling and in some cases removing the old electrical.
When we unstepped the mast, the hole that goes through the mast base (on the boat), had
the VHF antenna, the wires for the steaming light, and two wires connected to nothing. (the
previous owner taped up some plastic with electrical tape to keep water out (I assume thats
what it was there to do). I think they must have disconnected something. They don't look
like grounding wires.
Anyway, I'd like to make sure all this looks kosher and has the correct grounding. Does
someone have a photo of the mast step they can post? How should the mast be grounded?
will the step plate (the about 1/8" plate with what might be described as ears fore and aft
each with two holes in it) support a boom vang? Our boat was built in 1975.
While were on the subject, if anyone has converted to jiffy reefing can comment on how they
keep the boom from spinning (presuming you also added a track on the mast for the boom
to ride up an down in), that would be great, too.
Thanks and take care,
JH
JH
