I just noticed that the wire that connects the base of my mast compression post to the keel bolt has corroded and is no longer attached. I've looked at the owner's manual but don't see specs for the connector or ground wire. Right now the keel bolt is under 4" of very cold antifreeze, so I can't get a closer look. Has anyone worked on this connection before?
