Mast for 1987 Hynter 37
John Benz
I am repairing my 1987 Hunter 37 Legend after Katrina. It is necessary to replace the mast. The original mast was made by Isospar now Charleston Spars and it was tapered. I have received quotes from both Charleston Spars and U.S. Spars. The US Spars quote is about $4500 cheaper. It is not a tapered mast however. The Charleston Spars mast is more like the original. Question, what function does the taper perform and will the boat performance suffer without the taper? I understand that US Spars is now making Hunters masts and these are without a taper. Of course the boats are vastly different now. If anyone has any info on this or has replaced a mast on a 1987 Hunter 37 Legend I apreciate your comments.
Dec 2, 1999
15,184
more weight aloft
John: I would think that there will be more weight aloft if you have a non-tapered spar! Have you checked with Rig-rite to see if they can supply the OEM parts?
Dec 3, 2003
2,101
Talk to Hunter...
... and speak with their engineers. You may end up messing up the performance of the boat with a heavier mast.
