After raising the mast on my H26 I noticed that the foot of the mast does not sit flat on the tabernacle although the furler is pinned at the last hole. Where might I begin to look to solve the problem ?
Tim, The foot of the mast should lay flat. Sounds like you'll will need to loosen the rigging a little to allow this to happen and then retune. Check the archives for help retuning. There are some great posts discussing this.Jeff
