Today was high winds, cold and cloudy. Winds died away around 4pm so I went out to motor around a bit. I noticed something I do not know if I need to worry about or not.
First the set up:
The bottom of the hinge plate is bolted to the cabin top. The top of the hinge plate is bolted to a cast aluminum piece that is put in the bottom of the mast. Two nuts hold the hinge plate to the cast piece.
The cast piece appears to be rivited to the mast.
My shrouds could be a little tighter. I noticed the mast is rocking slightly side to side and found it is slightly loose on the hinge plate. Those two bolts need to be tightened but that means dropping the mast.
I don't mind doing that but it will have to be while on the water, tied to the dock.
Will I need to remove the cast piece or is it just studs and all I need to do is tighten the nuts?
Can I continue to sail for a couple of days and fix it when I get back home?
I hesitate to lower the mast while on the water as it is a job to balance it when it is on the trailer, let alone on water.
I just want to make sure I am not over thinking or over worrying about something that can wait to be fixed.
Thanks for the help!
Ward
First the set up:
Ward
