Poor factory design.
Mike's mast crutch is a better design than the original factory unit. With the original unit, the vertical tube inserts into a too small support (different than Mike's boat) that is attached inside the cockpit at the transom. Any side forces on the original crutch will cause that too small a support to rip the two screws right out of the fiberglass and cause the mast to fall aside. In doing so, the pop-top hatch has a crushing weight applied by the falling mast. Been there....done that. The only hope to salvage that poor original base for the original crutch is to re-enforce the support base with a large piece of 1/4 inch stainless steel plate to spread the load. I'm still looking for that piece of stainless steel.With my old Venture 2-22 that I just sold, I also had the "Mike design" crutch, but it was attached to the transom rudder fittings. That flat piece of wood was also a good base for a supplimental running light/brake light to be attached at the most rear position of your trailer. Such a light is required in California and Nevada, where I sail.
