Tie Down Crutch Too
If you are traveling with the mast attached to a crutch on the transom, be sure to tie the mast so that the crutch is held down well. My crutch's pintels slip down through the rudder gudgeons and once on a state highway under construction, they bounced up and out. This allowed the mast to slip cockeyed. I saw it quickly but had to drive a couple of miles before I could stop to fix it as we were in an escorted travel zone at the time. Since then I am careful to tie the crutch down as well as the mast to the crutch. Also be sure to start your trip with good, well greased wheel bearings and good tires, a solid trailer hitch and good trailer lights. Dick K.
