Mast coller block 89' Hunter 30G
Tim
Hello all! I need to replace the mast collar blocks on my H30G. I believe these bocks just have a threaded post on the bottom to screw them into the mast base collar. I need to order them before I will have a chance to get to the boat. Does anyone know the specs for an exact replacement? Thanks in advance, Tim
Jan 2, 2005
779
Hunter 35.5 Legend Lake Travis-Austin,TX
Going to be tough...
without going to boat first. You need to know for sure what brand spars were used, Kenyon, Isomat, etc. Then you need to go to RigRite website (link below) and do some digging. Dig deep, ;D , it is a hard site to navigate. Click on "Spars" then "Spar parts by mfg.", Look under Isomat for example. Click on "mast specifications and components" and go down chart and pick one. Look at NG31, I "think" those were used on Hunter 28.5 and 30/31s. It will then show you all the parts associated with that particular setup. What you are looking for is under "mast step" or "deck collar"...but you have to start out knowing which size/brand mast you have.
