Sorry Rich, but this is just not true and another one of those urban legends. The bridges in Florida are all marked on the tide boards at "low steel" at mean low low water, which is the lowest point of the bridge in the channel and not the center span. The Coast Guard, not the state of Florida is responsible for regulating bridges and signage. The fines to any bridge owner for incorrect signage is $25,000.00 per day per occurrence. If you or anyone believes a bridge sign has been tampered with they should immediately notify the local Coast Guard District. I had an opportunity to speak with Mr. Waverly Gregory, Bridge Administrator of the 5th Coast Guard District, at the AIWA Conference on November 18th about just that subject. The boards in the state of Florida are all correct reads at "low steel" unless they have been damaged, and those should be reported. ChuckGuys -
most of the bridges in Florida, these days, are purposely mis-marked on the 'depthboards' as maintained by the Florida Dept. of Transp. due to lawsuits from stupid people hitting the undersides of the bridges and the navigation lights that are suspended under these bridges..
In most of Fla. the FLDOT has artificially lowered the 'airgap' postings on most but not all bridges .... and NOBODY knows what the REAL bridge air-gaps are anymore; hence, the question.
mrmarch - I suggest you find a bascule bridge in close proximity to the Matanzas Pass bridge, call/telephone them and ask for info on the airgap of that bridge ...... and then LISTEN very carefully **between the lines** of their answer as to discern the 'real' airgap, because they 'for legal purposes' seemingly cant give you a 'straight answer'. Thats the way its done nowadays in Florida to find out 'airgaps' on any bridge that is 'doubtful' and 'legally mis-posted'.
Its surely turning into a entire country dominated completely by shysters, inane legal precedent, the pursuit of contingency fees and nothing relates to the TRUTH anymore.
Great idea, though with masts that tall, he might worry about getting between the uprights, as well as under the span. Lucky no one was coming the other way!MrMarch,
Tall mast? Low bridge? No trouble. Check out this video. It makes perfect sense. Trig the heel required, drop a line the appropriate length from the mast and add a tag line. Pretty simple stuff . . . I think!
http://www.youtube.com/watch?v=epz6BBZm__0&NR=1
Well Im going to totally disagree with you as the 'boards' MOSTLY now read to the *bottom of the nav lights* hanging down from the 'low steel' ... and the nav lights on MOST of the bridges from Palm Coast to Ft. Lauderdale have their boards reading 62-63 ft. at MEAN HIGH WATER ... and yes indeed, Ive had a few firm discussions with one of my US Senators, the 5th USCG district, etc. And the Senator's comment is: if the state has erroneously re-marked the bridges to other than the 'spec'. then the state has the responsibility to correct .... or to rip out the bridge and rebuild to the 65ft. spec. .... and these specific bridges under discussion are not 'arched' trusses (low steel at the support ends / high in the middle) but straight beam bridges. There IS a connection to actual lawsuit vs. FLDOT where a boat hit the nav. lights, damaged his vessel at less than mean high water ... and the FLDOT then 'raised the boards'. Been well documented ... and a legal work in progress, as its DANGEROUS to not know EXACTLY the air-gap on a bridge over a federally controlled navigational waterway.Sorry Rich, but this is just not true and another one of those urban legends. The bridges in Florida are all marked on the tide boards at "low steel" at mean low low water, which is the lowest point of the bridge in the channel and not the center span. The Coast Guard, not the state of Florida is responsible for regulating bridges and signage. The fines to any bridge owner for incorrect signage is $25,000.00 per day per occurrence. If you or anyone believes a bridge sign has been tampered with they should immediately notify the local Coast Guard District. I had an opportunity to speak with Mr. Waverly Gregory, Bridge Administrator of the 5th Coast Guard District, at the AIWA Conference on November 18th about just that subject. The boards in the state of Florida are all correct reads at "low steel" unless they have been damaged, and those should be reported. Chuck
