Mast, leaks, etc ...
On my Legend 35 (1987), I have been having water problems with my deck stepped mast. When it rains, I get water both coming down inside the mast and dripping through the wiring hole (which is in the center of the mast step) and then down inside the compression post, and also dripping down the outside of the post and onto the dining table. The water in the compression post ends up harmlessly in the bilge.The mast step casting does have a drain (out towards the bow) where any water collecting inside the step can/should drain out onto the deck, but the wiring hole is an even better drain, so that's where the water goes.If all my wiring junctions could be above deck level, then I'd happily use silicon to seal up the wiring as it goes through the wiring hole. All my mast lighting wiring have quick connects above deck, but my wind instruments go to a junction box below deck and thus sealing up the hole is not that practical.If I could move the wind instrument junction to a quick connect that was above deck, I could seal the wiring hole somewhat permanently with silicon goo and get all the moisture out.Chris
