Mast boot leak
Dec 29, 2012
148
Hunter 37 Jacksonville
Morning all,
I have a new to me Hunter 42 Passage. Picked it up last week and sailed toward home. Had a couple rainstorms and it is leaking into the cabin from the mast boot. Looked above and I don't seen anything to seal.
Can someone give me a clue about where and how to seal between the mast bottom and the cabin top please?
Dave
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Congratulations on your new 42!!
Do you have a mast deck wire housing just forward of the mast? If so, you can seal both sides. My Hunter 386 had a leak emanating from this housing when I purchased her and the previous owner just allowed it to leak down the compression post into the salon causing compression post rust stains. I sealed the housing and removed the rust stains.
Do you have a
Dec 29, 2012
148
Thanks for the info. I'll take a look when I get back to the boat. I'm sure you are correct. I briefly glanced at the base of the mast and didn't see anything that looked like a suspect.
