I have recently acquired a H336 (1996), and while lovingly gazing at her sitting at her slip, I noticed that the mast was pretty well bent back. I know the top section has pre-bend welded in, but the rest of the bend I assume is because of the rigging. Does anyone know how much bend is required?I also noticed that there was quite a lot of bend at the lower spreaders, and less at the upper. Is this the best way to share the bend between the two?
