Mast base plate replacement Hunter Legend 35.5 -recap
Jul 18, 2005
20
Hunter 35.5 Friday Harbor, WA
Hello-
I hauled out my 1991 Hunter Legend 35.5 last week to replace a long overdue mast base plate and thought I would throw out my lesson(s) learned on the matter since it's a rainy day. This is a deck-stepped mast, the cast aluminum base plate has been showing cracks around the screw holes (yes, I said screws, and not even tapered heads in a countersunk hole) and last summer an entire corner broke off. Pics are attached, it was time to address it...
- found the correct part at Rig-Rite, Inc
- most yards said they wanted to pull the mast off entirely. I'm cheap (I am a sailor, after all) and found a vendor that would just loosen the shrouds/backstay and hang it for a short while so the old one could be slipped out and the new one slipped in (yes, it was successful!). They used a telescoping forklift to accomplish this while the boat was on the hard. There was a ladder involved on the deck to attach the lifting strap and guide it a bit, glad it wasn't me. Plan on cutting the VHF connection, it didn't fit through the channel in the cabin top. There was about 2' of extra cabling to allow for this, many times over.
- the vendor tells me there were two issues with the installation: hex head screws/washers on the topside used in tapered holes) instead of through-bolts (I knew this before we started), and the screws were too large which is really what he thinks caused the problem ultimately. It has been a Pacific NW boat since day one, so I'm sure the blame lies with the yard that processed these arrivals and not Hunter.
That's it, I'm happy with the result (though I haven't seen the bill yet, lol). Feeling much more seaworthy now, whew.
5,951
Well done. Different model here, but our step plate has four through deck bolts the secure it to the coach roof. Hope to see you out on the water. Heading north any time soon?
Nice write-up @LoriPetersen which yard did you use?
Congrats on getting your boat shipshape.
Fair Winds. Have a great season.
Jul 18, 2005
20
Updating my profile to reflect that I am now in Friday Harbor, WA (5 years now, oops).
Hauled the boat out in Friday Harbor at Jensen's Boatyard which is now run by the Port of Friday Harbor for do-it-yourself work (or hire contractors). The tide is a little tricky as it's shallow at the pier, it is basically 0" at 0 tide, so planning around that is a challenge, especially around solstice (higher water did not necessarily coincide with business hours). The yard guys were awesome and worked with us a bit for an earlier than normal haulout, it was windy so they bumped the staff to 4 and were there at 7am to run the travelift/grab the boat -I had to back in a little hot with the wind on my nose and concrete pillars to aim between, yikes).
For the contract work I used Peace Marine Services (Mitch and crew) who did a fabulous job, they know their stuff and are in high demand. They're a little hard to pin down to a schedule, but once you get them, they are awesome.
Definitely heading out for a couple of months. First some San Juan Island cruising with friends, and then north to Gulf Islands/Desolation Sound for the remainder of the summer.
I’ll be on the lookout, in case we are cruising the same waters.
Thanks for the update on Friday Harbor capabilities. Nice to know.
Have a great Summer cruise.
Likes: LoriPetersen
DYFLWD
Feb 20, 2016
54
Hunter Legend 35.5 Lake Texoma
What is that small line that is tied off used for? I have one on my boat and have no idea what it is for.
