C
Chuck Mac Laren
I have a Hunter 27 1980. Here is my problem. at the base of the mast on the exterrior of the deck there is an indentation in the fiberglass it has been compressed over the years. This causes water to pool up and in turn laek through the deck and into the cabin liner and the new mast support. I have replaced the mast support and have even cut through thr cabin liner thinking I would be able to jack up the mast in order to support it and rmove the indentation where the water pools. Now I realize that the fiberglass that the mast base comes in contact with has a space between it and the cabin roof. If this space was filled with endgrain balsa as the caabin roof then It to has colapsed. By knowing what the design of this area of the boat was I hope to be able to come up with the best sollution to my problem.
