We recently had an accident caused by a stuck throttle on our outboard motor. The result was that the casting that the mast attaches to was pulled off the wooden block that it was screwed to on the top of the cabin. No damage was done to the casting and it appears that it could be screwed back down. We need to figure out if there is a good appoxy type product that could be used to repair the holes that the screws were in. Would it be possible, or advisable to bolt the casting back on the wood plate straight thru to the cabin ceiling?
Thanks
Thanks
