mast bail?
Richard
'nuther easy one! Can someone tell me if a 3 inch wide mast bail will fit on the Z Spars mast of my 1987 H23? Also, how does one go about attaching such an item to use with a boom vang? I was thinking pop rivets. Thanks! Richard H23 "Invictus"
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
It should work
I attached a bail (can't remember the size but it was a close fit) just above the mast base with a couple of #14 cap-head stainless steel sheet metal screws. I ground the tips off the screws so there were no sharp edges inside the mast to foul the main halyard. I used a third screw to start the holes and cut threads in the sides of the mast. The bail carries turning blocks for the vang and cunningham. Both lines go through a deck organizer on the stbd side then aft to cam cleats on the cabin top. I haven't had any problems and don't really anticipate any because I basically copied the setup from two other local H23's (no reported problems). I suspect the aluminum around the screws would probably fail in shear before one of the screws does. Good luck. Peter H23 "Raven"
Sep 25, 1999
601
Hunter 23.5 Indian Lake
bail
Pop rivets worked for me, not sure of the size for the bail , boat is in storage or I could measure for you good luck Mike Bacome
