Tiny Bit Of Help...
..Check on this site for the specs on your stock prop. Look under the boats section for the 28.5, then under specifications. You will find two props listed, a two and a three blade. If you call Martec at 562 / 435-4494, they will give you a recommendation. It may not be the same as the stock size depending on the prop you select. Rick D.
