Marinebeam LEDs - my experience
Jun 4, 2004
255
Hunter 376 Annapolis MD
I gave Marinebeam the data on my present incandescent bulbs.
Marinebeam said their model WG-BP-10-WW bulbs are their LED replacements for them.
Based on that, I ordered two.
They did not fit in the lamp socket. The base of the LED is different than the base of the incandescent (See below my engineering analysis that I gave to Marinebeam).
I refused to accept the LEDs since they were not replacements and Marinebeam told me to return them. I did and they acknowledged receiving them.
Thus, Marinebeam made an error (which wasted a lot of my time).
In addition, after they received the items, they did not issue a credit to my credit card. After two weeks, I finally contacted them and asked when they will issue the credit. Only then, after I pressed them, did they issue a partial credit; they retained some of my money for the shipping cost that was incurred due to their error.
Also, they are not reimbursing me for the costs I incurred shipping the items back to them because of their error (Since they chose not to issue a call tag, I had to incur cost in time and money to drive to the next town, the closest post office, to pay to ship it back and get a proof of mailing.)
It appears to me that they do not treat customers in a fair and reasonable way.
Allan Frey
Engineering analysis
I used a fractional scale vernier caliper to make the measurements (I was a GE engineer).
In the metric terms that Marinebeam uses, the lamp socket is 9.5 mm. The spring holder/contacts assembly in it, I photographed and sent to them. The wedge base bulb spreads the spring holder during insertion and, when fully in, it grips the bulb. This makes sense since the spreading of the spring holder from its rest position of about a 1 mm gap to a 2.4 mm gap provides the tension to hold the wedge base bulb in the holder.
The plastic of the Marinebeam LED assembly is 9.5 mm wide and 2.4 mm thick with the bottom squared off where it inserts into the holder.
The incandescent bulb is 9.5 mm wide and 2.4 mm thick where the holder grips it when it is fully seated in the socket, just as in the LED. But the bottom of the incandescent bulb, where it first inserts into the spring holder, is quite different from the LED. The four edges of the bottom are chamfered. In this way, the narrower bottom of the bulb, about 1 mm, readily slips into the spring holder and then spreads it as the bulb is pushed in. When fully inserted, the spring holder securely grips the wedge near the top where it is 2.4 mm thick.
It appears that the LED is stopped by the spring holder, because the lack of a chamfer does not allow the LED to slip into the spring holder to start the wedge action.
I also inserted a screwdriver, twisted it and the spring holder is flexible and moves easily.
Jan 4, 2006
7,161
I ordered a number of different bulbs from Marinebeam this last winter and had no problems with dimensions. Mind you, I didn't get a chance to see how they handled errors or returns.
Of all the different samples of LED's I've collected (and turfed into the scrap box) over the last few years, I found theirs to be the closest to tungsten light.
Perhaps if you could post the pictures you sent to Marinebeam along with any others you have, it would go a long way to describing the problem rather than just text.
Jun 11, 2011
1,243
Hunter 41 Lewes
I like Marine Beam products. I have never had any problem with them or their products. If it truly was their fault you should just call your CC company and have them issue a refund from your end. I don't allow the vendor to issue credit. I always have the credit issued from the bank/CC company.
Wow, sorry to hear about your "ordeal."
I'm surpised, however, 'cuz most of the "known" bulb BASES are standards.
What could it be that you may have missed?
Why have you blamed the vendor?
Aug 15, 2014
114
Catalina 36 Deale, MD
I installed four no name LED lamp fixtures from a big supplier last fall. They were nothing special and the light was too hot/blue. Installed two of the MarineBeam's LED lamp fixtures (with the blue glowing switch) for the v-birth over the weekend. These were so superior in every way over the ones installed last year, I ordered four more today to replace them. No longer shopping around for lights. MarineBeam is the place I will go.
Dec 25, 2000
5,906
Ditto My Marine Beam Experience
All of our incandescent bulbs have been replaced with MarineBeam brand bulbs. All have fit and work well on the first try. Those include:
Navigation lighting; anchor, steaming, running (port, starboard, stern).
Deck lighting; foredeck, stern deck, cockpit. The foredeck light bulb is a mini bayonet. It has one LED emitter. What a performer!
Six interior reading lights.
Thirteen four inch dome lights.
Four courtesy lights.
In every case I would describe in detail the type and identification of incandescent bulb and requested they select the correct replacement, which they did. I placed my order based on their recommendation. Every order arrived correct and on time.
I highly recommend their product and will choose them again if I ever need replacements.
Some time ago, when I began my search for a quality LED product, Maine Sail steered me to Marine Beam. Thanks again Maine Sail.
1,113
Allan Frey
The incandescent bulb is 9.5 mm wide and 2.4 mm thick where the holder grips it when it is fully seated in the socket, just as in the LED. But the bottom of the incandescentbulb, where it first inserts into the spring holder, is quite different from the LED. The four edges of the bottom are chamfered. In this way, the narrower bottom of the bulb, about 1 mm, readily slips into the spring holder and then spreads it as the bulb is pushed in. When fully inserted, the spring holder securely grips the wedge near the top where it is 2.4 mm thick.
Perhaps you confused the cretins with your precision....
Feb 6, 1998
11,701
While my own boat currently, as in today, has Sensibulbs, which I love, by the end of the week every bulb on-board will be Marinebeam because for my customers they represent a tremendous value in a high quality, quiet RF, LED bulb.
I use my boat as a place to showcase new technologies to my customers. These days lots of customers want to see LED's in action before committing. Too many have been burned by cheap "blue" LED's or RF noisy LED's. I even had one customer who's LED emitters un-soldered themselves from the circuit board and fell into the overhead dome..... "My cabin lights are not working can't be the bulbs they are brand new.".. Yeah brand new off FleaBay with no current regulation what so ever...... :cussing:
I know of at least 25 direct customers who have done the conversion themselves that I have sent to Marinebeam who are extremely happy with zero complaints. There are likely many more via my web site and the forums who've bought from Marinebeam too. I've not had any complaints. When I suggest a product, and folks are not happy, I DO HEAR ABOUT IT.
I have done perhaps a dozen Marinebeam full conversions for customers who can't even change a light bulb, and yes they do exist. Again not one single issue or fitment complaint on any of those bulbs. I have also installed many of the exact bulb Alan had (this bulb is widely used on Ablin power boats with Guest overhead fixtures) and never once had a fitment issue. Keep in mind these bulbs press in firmly but they fit well and don't fall out.
Jeff has been absolutely incredible to deal with and has always stood behind a shipping issue. On one order they forgot a bulb. I picked up the phone, called, and Jeff sent it to me overnight. I also had a small freak issue with one of his wind generators which he 150% stood behind as well. They are human just like everyone else and because of that even the best of the best can make mistakes.
Pick up the phone and call Jeff Field in person. He does return phone calls and is extremely reasonable.
I agree with others we need to see some photos because the text is not describing the issue clearly..
Feb 8, 2014
1,300
Columbia 36 Muskegon
Against everyone's advice here, I bought a bunch of LED bulbs on eBay (actually bought them before reading the posts). At $2.50 each I can throw them away if they don't work. So far all's good. They're brighter than the originals, although a little blue, charging voltage doesn't seem to bother them and I haven't had any RF interference. And way cheaper than Marinebeam.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
ok i am going to chime in here .....you can use whatever you think will satisfy your lighting needs...but remember that it may not be compliant with anything ...in mainsails case he is selling service to his customers and has seen a lot of fuba in his day...that being said he also has to give good quality service for the price he's charging for several reasons ...one being to have a happy client along with a client return and on the hidden side he has an obligation and liability to protect so as a result he gives the top notch end of recommendations in order to accomplish his and his customers objectives.... as a result of doing this he has a very strong and thriving service company (successful if you will)......
now having said that why would anyone argue with success
Feb 8, 2014
1,300
I probably just got lucky on my LEDs, if I was paying for installation or even a recommendation, I would certainly expect the best. I bought mine as an experiment, and it worked. I now know others have had problems with the cheap ones.
May 6, 2010
472
1984 Oday 39 79 Milwaukee
Just changed all of our interior lighting to MarineBeam
I had changed a few of our incandescent bulbs to SensiBulbs a couple of years ago, and while the light was good, the bulbs themselves with the socket adaptors were somewhat finicky and, I thought, fairly delicate.
After reading one of MaineSails reviews, I went to the MarineBeam website and using the information provided there, spec'd all my own replacement bulbs as well as a few additional fixtures.
My order came very quickly, and I installed all of the product two weekends ago, and I could not be happier. Everything fit well, was of high quality construction, and in my opinion (granted not an apples to apples comparison) the light is better quality and spectrum than the SensiBulbs I replaced.
The MarineBeam website has a bulb identifier which worked for me and seems like it would be more intuitive than a set of calipers, but then I'm not an engineer.
Your mileage may vary, but I am an extremely happy customer and will be replacing all of my exterior lighting next.
Scott
Johnb
Hunter 37-cutter Richmond CA
To be totally fair it should be remembered that the output and color of LED's has changed hugely in the last couple of years. No doubt the improvement will continue.
Jun 4, 2015
7
hunter 37.5 Gulf Breeze
Allan - we had exactly the same experience on our Hunter 37.5. Bought the same bulbs from Marinebeam & they did not fit, although they sure looked like they should fit. I believe your engineering analysis is spot on. After reading this thread, though, we're going to try again tomorrow - maybe wiggling the wedge end into the socket & pushing hard.
Feb 6, 1998
11,701
Coat the end with a bit of dielectric grease, press firmly and they should pop right in.. I've done a fair number of these....
Jun 4, 2004
255
[FONT=&quot]Marinebeam LEDs – Arbitrator’s ruling [/FONT][FONT=&quot] [/FONT]
[FONT=&quot]I filed an arbitration case. The arbitrator investigated and ruled in my favor. The amount of money that Marinebeam had withheld has been returned to me.[/FONT]
[FONT=&quot]Below is my original posting describing the case:[/FONT]
[FONT=&quot]I gave Marinebeam the data on my present incandescent bulbs.
Allan Frey
I also inserted a screwdriver, twisted it and the spring holder is flexible and moves easily. [/FONT]
Jun 4, 2015
7
Thanks Ben. Can you tell me which bulbs you got for the interior dome & swivel reading lights?
Jun 4, 2015
7
Turns out the LED bulbs work just fine. Just need to put them in a slight angle, then wiggle them in. This was just a trial for our interior dome & swivel lights but we plan on replacing them all now. Thanks for all the advice.
Jul 27, 2013
298
Hunter 37.5 1065 Rock Hall, MD
I am at the boat. I will send you the bulb model number tomorrow when I get home. I did all my lights with LED.
Ben
