MarineAir Heat Pumps
Dec 25, 2000
5,946
Amazing devices these reverse cycle heat pumps, how they can extract heat from 40-45 degree water in sufficient quantity to warm the boat to a comfortable temperature or cool the boat from 70 degree water. Both units on our 1991 boat are original and consume about ten amps each when connected to shore power or running the 8kw Genset.
The 16K BTU main cabin heat pump warms/cools the main and forward cabin and forward head with the 9K BTU heat pump for the aft cabin and head. Other than opening a through hull valve, flipping a few switches and turning a knob, that's it. They just run until you turn them off. PNW weather never reaches a temperature that requires cooling, but warming during the off season does come in handy.
When we took possession in 2002 the PO had removed the main cabin heat pump for repairs, as I recall to replace the compressor. Some speculation as to what happened, but that is what it is, a guess. We've used that one the most when at the dock connected to shore power when we had no plans to venture out during the colder months of the year. The aft cabin heat pump has been used some, too, but both very little over the years. We tend to use the Wallas diesel furnace the most during the cold winter cruises and/or while at anchor.
I've noticed lately that the aft cabin unit produced some heat but it never reached the set temperature when it would cycle on and off to maintain cabin comfort like the forward cabin unit. This past winter it produced no heat, so it seemed time to have someone take a look see.
Our marina office had a business card for Ice Boat Marine (Woody Wentworth) out of Anacortes so I gave him a call awhile ago to place an order for that look see. Yesterday was that day. He left me a message to tell me that he did his work and both units were operating to spec. He was a bit surprised to see that our units were the oldest that he has come across. No leaks were found in the aft cabin unit, but it did take nine ounces of R22 refrigerant, which would explain the absence of heat output. His bill was $222.00 for three hours of work, which all things considered, pretty reasonable considering the current price of R22.
Some thoughts about a dead compressor, or crapped out condenser crossed my mind, but those have now been put to rest. Memorial Day 2017 weekend has arrived with three days off, so you can guess what this skipper plans on doing and it won't be weeding in the yard.
Terry, You must banish such negative thoughts or they may come back to haunt your strong sturdy working machines... Good news regarding the discovery of "Woody, in Anacortes". Sounds like the guy you want to know and help solve those problems that require special skills.
Sail in fair winds and smiling seas this weekend.
John
Dec 25, 2000
5,946
Hi John, thanks for your inspirational comments. Woody was a shot in the dark. Hopefully, his work will turn out okay. Took awhile before he found time to fix our machine; one of his techs quit and moved back to Canada just when he was trying to finish up a large boat project. Weekend weather holds much promise.
7,497
Alden 50 Sarasota, Florida
But a lottery ticket. It sounds like your lucky day.
From your description, it sounds like you expected the worst. You know what they say - "pessimists are never disappointed"
Mar 3, 2003
710
Hunter 356 Grand Rivers
We use ours for heating and cooling on Kentucky Lake. When we leave the dock, the generator powers it. We've been warm in 44 degree water temp,but the boat surfaces must get heated up and that sometimes takes a day of operations before the cold soaked boat mass gets to normal temps. Ours still going strong after 15 seasons.
Nov 6, 2006
10,113
I installed a 12K BTU unit in the boat back in 1992.. It runs almost all the time in "Dehumidify" mode (every 4 hours, it turns on and cools the air 1deg F to get the water out, day/night when we aren't there).. In the summer when we are there, the AC runs constantly, except when sailing.. In the winter it is mighty fine to warm the boat on those evenings/nights when the temp is in the 40's or below.. Our water rarely gets much colder than 55-60 so it does a fine job of warming.. I had a compressor fail but that was because the drip pan held a level of water that touched the bottom of the compressor body.. That corroded a hole through the case.. not a Marine Air problem.. since I replaced the compressor, I have shimmed the pan so it does not hold water anymore.. I am very pleased with the unit.
Dec 25, 2000
5,946
Spent the Holiday long weekend out on the boat. Checked Woody's aft cabin heat pump repair. Yup, it puts out the heat, far more than it ever did since we purchase Belle-Vie in 2002. Happy camper, er, boater here. Some photos of this little, but very efficient, 9K BTU device:
He also checked the main cabin 16K BTU heat pump just to make sure it was also within spec and it was. Both also output cold air if we need it, but never seem to in PNW climes. Nice to have a warm boat while at the dock during the winter months.
