Marine toilets
Aug 27, 2015
58
Cal 2-46 Whitianga. New Zealand
We are cruising in Vava'u. Tonga.
We have two TMC electric toilets. They never give us a problem. But two days ago one started to really stink. I cleaned and flushed etc. etc. and then when scrubbing under the rim out came a gooey slime ribbon of slimy stuff. It appears we have sucked in a jelly fish. And try as I have I cannot get it all out.
And it still stinks.
Anyone got any suggestions??
Pete
Dec 2, 1997
8,944
- - LIttle Rock
Disconnect the toilet intake line from the thru-hull (close the seacock first!!). Fill a bucket with clean fresh water to which you've added a quart/liter of distilled white vinegar....flush the whole bucketful through the toilet. That will clean out the intake line and the pump. A second bucketful of water and vinegar may or may not clean out the channel in the rim of the bowl...if it doesn't, the only solution will be to remove the bowl to set it on the dock and blast it out with a hose.
I suggest you also install a strainer in the intake line as close to prevent this happening again. It should be installed as close to the thru-hull as possible while still accessible to be checked and cleaned out as needed.
I've had to deal with a few of these over the years...the worst ever was the remains of a baby octopus. You have my sympathy.
Jul 12, 2011
1,165
Leopard 40 Jupiter, Florida
If I remember correctly, you have previously advised to re-route the sink/shower drain to the head inlet to free up a through-hull and make winterizing easier. I assume that your suggestion of a raw water strainer would be outside of this arrangement? The raw water strainer would be after a t-connection and only be for the inlet lines? The sink drain would be the other half of that line and go directly to the seacock.
Dec 2, 1997
8,944
- - LIttle Rock
I have to confess that it's never occurred to me to add a strainer to the sink drain installation...most likely 'cuz I've never heard of anyone who needed one. So I need to think about it. But meanwhile, my "top of the head" thought is, a head intake line connected to a thru-hull is only a one way street...whatever gets sucked into it gets pulled further into it with every flush. But enough water goes down the sink drain regularly enough to wash anything out that gets pulled in before it can get pulled in even as far as the tee.
Y'all's input is welcome.
Jul 12, 2011
1,165
Actually, I was suggesting that if the sink/shower drain and head intake share the same through-hull, you would only want to install a strainer on the head intake. Otherwise, you would be filtering the output of the sink as it flowed out. I've not yet re-plumbed mine yet to share the through-hull, but probably will when I install a washdown pump using the current head intake.
DaveJ
Apr 2, 2013
487
There is no proper spelling of " y'alls "........
Dec 2, 1997
8,944
- - LIttle Rock
Your memory has it backward and also added a shower drain line that doesn't belong in it....you never want to use gray water (galley, bath or shower water) to flush a toilet...all the soap scum, hair, body oils etc in it will clog up the pump.
It's the head intake line that you want to reroute to tee into the sink drain line, below the waterline as close to the thru-hull as possible. This allows you to flush with sea water normally until you're preparing the boat to sit (or find yourself in waters too skanky to want to use). Then, after you've closed all the seacocks (you DO close them when leaving the boat?!), fill the sink with clean fresh water...flush the toilet. Because the sink drain seacock is closed, the toilet pulls the water out of the sink, rinsing the sea water out of the entire system--intake line, pump, channel in the rim of the bowl AND the toilet discharge line. Just flushing water added to the bowl only rinses out the toilet discharge line.
I'm impressed with your ability to spell " y'all's " correctly.
:biggrin:
DaveJ
Apr 2, 2013
487
Wow! I'm honoured. PM me and we will set something up.
Cheers
PS- Canadian spelling of honoured....
Kermit
Jul 31, 2010
5,673
Yes there is. You just didn't get it right. Peggie did. (Do we need a new thread on correct usage of proper nouns?)
Hagar
Catalina 42 Olympia Washington
Hey, hey, hey! What makes you'uns'es think you can hijack a sailing thread for grammar purposes? ;)
Likes: Kermit
SFS
Aug 18, 2015
2,085
Currently Boatless Okinawa
I'm sitting here chuckling, because to convey "y'all's" properly, as Peggie did, punctuation is more critical than the spelling aspect. A possessive contraction, who'd a thunk it?
Kermit
Jul 31, 2010
5,673
Plural possessive: All y'all's
Likes: Camchain
Aug 27, 2015
58
Incidentally in NZ the plural of you is Yous. At least in some areas.
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
It's not "you'uns'es", it's "y'uns".
:biggrin:
