Marine Toilet
12
- - Sydney
I currently have the original Wilcox Crittenden manual head on my Hunter 356 and decided to service it after many years of use. Using the maintenance kit, I set about replacing the appropriate parts including the Inlet flap valve assembly (part 9). However, when reinstalling the Housing cover, It now leaks around the sides of the housing cover (part no.8).
Can someone advise on the correct way to install the inlet flap valve assembly (hopefully with a picture when it is in position) and how to prevent the leaks. Many thanks, Lance
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Can you post a photo showing the parts that is the problem,I had a Wilcox so maybe I can help.
Nick
