ABYC Standards
American Boat & Yacht Council has a complete set of boat systems standards, including wiring and boat piping. Boat builders follow them (most of 'em anyway) and ABYC standards, along with UL (UL has a marine code too), NFPA (National Fire Protection Association), and USCG standards are what surveyors--the good ones, anyway--use.They're not free, though...you have to buy them, and they're not cheap. Unless you're planning to rip it all out and start over including relocating thru-hulls, they're prob'ly not worth the expense.A chapter in my book (which is scheduled to be out in 3 weeks) is devoted to standards for sanitation systems. However, In a nutshell, the piping standard requires that:Hoses should be of the type rated for their intended use--potable water, fuel, exhaust, below waterline connections or above waterline only etc--and hose mfrs' specs indicate which hoses should be used for a particular application. All connections should be double clamped.All seacocks and valves should be readily accesssible.Vented loops are required in most hoses connected to below waterline through-hulls.If any hard pipe is used, it should be "soft coupled" to all rigid or fixed equipment and thru-hulls with enough hose to cushion shock and allow for flex.As for types of valves and fittings, it has much to do with common sense as any standard--mixing some metals can result in galvanic corrosion, because plastic and metal have different thermal coefficients, metal fittings in a plastic tank can result in a cracked tank, ball valves are more reliable than gate valves, etc. There's a lot of room between the minimum standard and the best quality...If I knew what you're up to, I can prob'ly advise you about what to use and how to install it.
