marine heads
Tom
My 1990 Hunter 30 needs a new toilet. Would appreciate any opinions on the best brand to buy. Currently, we have a Jabsco. Very poorly made. Thank you for the input!
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Electric
I installed a Raritan Electric Atlantas Freedom unit and love it. Also installed a larger holding tank.
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
Save some dough and go manual
I went with the Raritan PH-II in my Hunter 34, replacing my Jabsco was a no-brainer. I ripped everything head related out and got all new. The PH-II you will find is one of the best heads under 500 bucks. I had to mount a small 12x8x1/2 starboard mounting plate to the liner and then attach the new head to the mounting plate - not difficult just time consuming. Dont let size/shape limit you back to Jabsco. Refit with a better head. You should also think about upgrading your discharge pump while your at it. Also think about hoses while your at it - 1990 hoses are now 17 years old! Oh- make sure you pump out/rinse a couple of cycles for a more "pleasurable" head re-fit project. Good Luck!
Douglas Washburn
Echo Guy's comment...
We installed the Raritan PH-II, replacing a Jabsco that had been and ongoing maintenance issue, and could not be happier with the results.
