Marine head
2
- - olympia,wa
Hello fellow rangers,, I have a simple ? to ask does anyone know what type of manual heads will mount up with the original head I am looking to replace mine any help please.....
May 7, 2007
2
- - olympia,wa
Feb 6, 2006
249
Hunter 23 Bay Shore, LI, NY
Post this in the Headmistress forum
and give much more information (what type of head, etc)
Feb 6, 2006
249
Dec 2, 1997
9,010
- - LIttle Rock
If the toilet is more than a few years old
It's unlikely that even the same make/model mounting bolt pattern will be an exact match for all the existing holes 'cuz, like most other things, marine toilets are redesigned--either just for style or using improved (or cheaper in some cases) materials. But that's not a major problem...you'll just have to drill a couple new holes, fill and touch up the unused ones. On a boat that size of yours, your toilet is almost certain to be a compact manual. Jabsco is the cheapest, least durable/reliable...the Wilcox Headmate is slightly better quality...both are <$200. Between $200-300 the Groco HF is somewhat better quality...the Raritan PHC--which is the PH II pump on a compact base is--as many owners will attest--the best most durable by far. It's tempting to buy the cheapest, but like most things, you get what you pay for. You'll spend far more repairing and even replacing a cheap toilet every year or two than it'll cost you to buy a good one just once.
Dec 2, 1997
9,010
- - LIttle Rock
