Marine Head Lever Position
20
Catalina 1977 San Diego, CA
What position should the lever be in when the head is not being used? Flush or Pump Dry? Is there usually fluid in the head (1/4 full) when not being used for a extended period of time? Thanks.
What head? Ours is a W/C Head Mate. I leave it on fill not flush.
May 23, 2004
3,319
On my Raritan PH II I leave mine on Dry. I think that I did the same on my Jabsco. Don't forget to close the through hull when you are underway unless you have a vented loop in the intake line.
