I built a boat ... My experience...
I built the D4 that is refered to in the previous link. You do not need to use marine plywood. However, I do have the following comments.1 - When you select your plywood, BE VERY CAREFUL OF VOIDS - these are the spaces between the layers and when you bend the plywood even a small amount it can crack at these places. I know from experience! Yo may have to dig through the pile, but it's worth it.2 - If you decide to epoxy the thing (whatever it is) make sure you do a little bit of "learning" before you start. Take the time to learn how to mix, create a test project and learn how the resin sets up etc. If you mix it wrong, it's a pain to scrape off (again experience talking) and have to do it again.Otherwise, it's a very fullfilling experience to build a small boat. Geof
