Marine gear lubrication oil
Oct 25, 2015
26
Beneteau 343 Ruskin FL
I have a Yanmar 3MY30 engine and the manual does not specify a marine gear lubrication oil for the transmission. Any recommendations. The engine takes 15W-40 and I have that covered.
Dec 25, 2000
5,950
Our Yanmar (4JH2-TE) has an identification plate on the bell housing between the transmission and engine that states the type of transmission lubricate. Our service manual and owner's manual conflict as to which. Your engine should have that identification plate. I would follow what it says.
Likes: kloudie1
Oct 25, 2015
26
Thank you very much. Found it on the backside of the transmission. SEA 20/30HD.
Dec 25, 2000
5,950
As a side note, our transmission dip stick has a ring just above the bottom of the tube, maybe 3/16th inch. That is the full mark and measured with the dip stick cap resting on the transmission housing, not screwed in.
Oct 25, 2015
26
Thanks again.....mine has the same and it was driving me nuts to figure how much oil to put in so I just measured with a measuring cup the amount called for in the manual, .6pints or little over a cup. I will look at the stick today and see where the level is at.
Dec 25, 2000
5,950
Hmm. Seems not enough, IMHO. Then again maybe our Kanzaki is larger and takes more lubricate; almost a full quart of ATF to bring the level to the dip stick mark.
Oct 25, 2015
26
Now you got me worried. I will relook the manual today and check the dip stick.
Sep 20, 2006
2,952
Kanzaki in the 3YM30 takes .3 litres ( or just over .6 pints ) of HD 30W oil. Just did mine over the weekend.
Feb 8, 2014
1,300
Columbia 36 Muskegon
My Hurth takes the same amount, . 6 pint. ATF on that one though. Don't know what they do if over filled, but with that little amount there's not much distance between a little low and empty. So check it often.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
Any tricks for reading the dip stick? When I pull it out it fit so tight it seems to wipe itself dry. Also the oil is clear in the first place so twice as difficult. I wish they made a dye for guys with bad eyes in tight spaces.
Don't wipe it. Just roll it on a paper towel, you'll see it clearly. Good luck.
Oct 25, 2015
26
I even pulled the printout out today while sailing to make sure I read it right...and your right...watch that often.
Oct 29, 2005
2,366
Stu thanks for the tip on using paper towel. I've been struggling all these years trying to read the level with that dip stick.
