Marine Air /electrolysis - bonding
L
lheidngsfelder
My refrigeration guy was asking about electrolysis problems with marine units. It seems I've been developing what he considers leaks on the "high" side of unit due to possible electrolysis ( due to lack of bonding ? / different metals ?) This is a reverse cooling/heating unit 16,000 btu's (Marine Air) and really not used much. He's repaired a leak and sniffed I think two more. Any recomendations ??? Thanks for the help.!!
Patrick Neeley
Marine HVAC
I have a 30T with an Ocean Marine HVAC after market installed. Wouldn't doubt your service man's observation. Mine has eaten up the s/s fine mesh screen in the Sherwood raw water strainer pretty severely and I only open the seacock when in use - rarely. Had a difficult time finding a replacement, which tells me this is not a common problem. I will eagerly await suggested solutions from the HOW techs.
Bill Thomas
ELECTROLYSIS
You need to have the boat checked by a marine electrician to find and cure the cause for this. Losing a screen or developing a refrigerant leak due to electrolysis is not a big deal when compared to the catastrophic possibility of losing a thru-hull.
