Maps and Other Sailing Questions
If sailing were just getting on the point and raising the sails, there would be more sailors, I suppose. Your question reflects a lack of a good basic sailing course. Depending on your sailing grounds (lake or coastal ocean waters), you should take some sailing courses to answer these questions BEFORE you it's time to ask them.Though I thought I knew how to sail when I moved to New England, 5 courses later (including a navigation course) I STILL am not sure I know enough. Needless to say, knowing where you are at all times is critical. As the prior replies noted, good cruising guides are a must along with up to date charts, a compass, maybe a GPS AND the knowledge to use them. Otherwise you'll be calling the Coast Guard for directions, an embarassing call for any sailor!
