Many questions about the Yamaha 25 MKII
Yam
Jul 29, 2012
4
Yamaha 25 MK II Naarden
Hi guys,
I have many questions about my boat.
- Does anyone know Magician V and know the differences between her and a standard yamaha 25 MKII ?
- Does anyone know the rating of the 25 MKII ?
I want to participate to the round of the island of Wight in the category quarter-tonner, just for fun since i have seen about 10 boats in Cowes that were far more equipped than mine.
I have another question; when i went with my boat to England i took a force 5 with gusts at 6 and my riggings under the wind were loose. Do you have the same problem ?
Maybe my riggings are too old and the best idea would be to replace them by Dyneema riggings or new stainless steel.
Thanks in advance for your answer !
Yam
http://www.youtube.com/watch?v=5H2bIQ0vOGg
jnovie
Jan 28, 2009
54
Yamaha 26 tall rig Marina Village Alameda, CA
Hi guys,
Yam
Here is a link to some images of Magician V:
http://www.boatdesign.net/forums/at...quarter-tonners-magic-bus-japanquarterton.jpg
Here is a link to Quarter Ton Class UK. They should be able to provide information on the rating for your boat or at least direct you where to the right source:
http://www.quartertonclass.org/
You might also try the Japan Sailing Site for and search for info on Magician V:
http://www.sail-japan.info/site/index.php
Jan 4, 2008
149
Yamaha Y25 mkII Long Beach, Ca.
Rig tension
welcome aboard, I've never seen my rigging loose. Just took a look at my rig using a Loos&Co Model PT1 tension guage.
the # on my boat are:
Fwd Lower shroud -- 35lbs
Center Upper shroud--- 35lbs
Aft Lower shroud-- 37lbs
Forestay /backstay vary with adjustable backstay. I run it tight in any breeze to eliminate forestay sag. My boat has Dyform rigging so the numbers probably vary boat to boat.
I have a factory manual that goes into rigging pretty deep. I can send you a copy for the cost of Copying and Post, arround $20 USD, drop me a line at syntonossailor@yahoo.com if interested.
Others say they have an electronic version available. Check out the previous posts there is a lot of info, we've been very active
