Okay I am really confused. I have the 1983 hunter 31, dry dock. At the forward Starboard side below the water line directly below the bathroom area are two through hull holes one large and one small. Inside the Lav under the sink are 2 valves: a Red valve handle connect to a large hose and then a blue valve handle connected to a smaller hose.
The Hunter 31 manual plumbing diagram: shows a label #12 Manual waste pump that is located in in the Bow Berth. It is directly stern of the lav holding tank.
I have looked everywhere for the manual waste pump and can not find. Can some help with it any ideas?
What is the red valve and what is the blue valve?
What are the two through hull holes large and small below the water line?
My Guesses:
It appears the blue valve is to allow water from the smaller through hull to go into the head and possible the red valve is to allow it to dump overboard through the larger. But I have tried flushing clean water with the red valve open but nothing is coming out, I expect this needs the manual waste pump?
My Guesses:
