Manual Head Recommendations
5
Catalina 30 Galveston TX
Peggy, Just found your forum. Reviewed most of the past posts and noticed that you recommended the Raritan RHC which I can not find. Do you have a current recommendation and what is the latest on OdorSafe? Thanks, Denny Fegan
Dec 2, 1997
8,962
- - LIttle Rock
Raritan PH II or PHC
The PHC has the same pump as the PH II, but on a compact base to fit in a tighter space. You'll find everything you need to know about it here: http://www.raritaneng.com/products/toilets/manual/ph_2.html The original OdorSafe hose was SeaLand's private label brand name for AVS96, made by Australian Global Services...proven in independent testing to be at least 16x more resistant to odor permeation than ANY other hose in the world. Not long after Dometic—a European mfr who specializes primarily in RV equipment--acquired SeaLand from N.A. Taylor in 2003, SeaLand switched to an Italian hose mfr for their "new and improved" OdorSafePlus brand hose. Is it as good as AVS96? Weelll…it was included in the original tests that proved AVS to be at least 16x better than ANY other hose. AussieGlobe is now selling their AVS96 hose direct here in the US--and for a LOT less than SeaLand charged for it, or for their new OdorsafePlus...$5/ft, cut to any length vs. nearly $9/ft for SeaLand in min. 50' coils. Their website is at http://www.aussieglobe.com/avs96.htm
