yanmar manual
Dear Glentry Mack Boring, http://www.mackboring.com or 1 800–622-5364, ask for Tony in parts ext 220. When he quotes a price tell him you saw it cheaper at diesel direct and he will match the price. I received my manual in 2 days.I just purchased the service manual in addition to the standard owners manual. If you have a new engine (as I did on my "new" 322) install an hour meter if you don't have one. I connected the meter's positive lead to the red/black terminal on the backside of the ignition switch. It will only feed juice to the meter when the key is in the on position. The alarm will remind you when the key is "on" and the engine isn't. You can snake a wire from your instrument panel to the engine compartment from in back of the panel with the stereo/fm-am receiver, there's a plastic tube in back of the panel for snaking wires fore & aft but I had difficulty getting my wire snake around all the bends. I finally snaked it down the core of wires in back of the trash receptacle, under the nav seat "floor" and the head floor under the shelves below the sink to the engine compartment. Its about a 2 beer job, but worth it as you will be able to keep an accurate log of the engine hours. If you do add it I believe you should use purple wire for the positive feed from the switch to the meter.Best wishes with your new 322.Ed
