Manual Bilge Pump
Terry
Does any P42 owner have a manual bilge pump installed on their boat? If so where did you locate the pump and how did you route the plumbing? Thanks. Terry S/V Belle-Vie
H
Henry Rozanski
Whaler Pump
I have a manual pump installed in my 1996 P42 which was there when I bought the boat two years ago. It's mounted in the floor of the cockpit behind the wheel which means it's bolted to the roof of the engine compartment. The pick-up tube is in the bilge compartment right in front of the steps to the main hatch. I'm sorry but I'm not sure where the exhaust hose is rounted to but I gues you'd have several options from this installation point. Hope this helps.
V
Victor Robert
My P42 has a manual bilge pump located in the cockpit floor just starboard of the Edson binacle. The body of the pump is just above the inverter in the battery compartment. The pump is worked by inserting a 12" rod into the faceplate in the cockpit floor. I had assumed that this was standard equipment from the factory, but now that you mention it, there are a couple of covered screw holes near the pump which imply a modification. I had an unplanned opportunity to try out this pump when the bilge pump switch failed a few months ago. My conclusion from this test is that the manual pump is useless. I worked up a serious sweat in 90 degree temperatures, gave up from exhaustion, and could not detect a drop in the bilge water level. It felt like all my energy was going toward fighting the pump, instead of lifting water out of the bilge. A design flaw appears to be the fact that the output of the pump feeds into one of the cockpit drain hoses which then goes to a through-hull in the bottom of the boat. It felt like I was forcing water into this hose and then into the ocean, constantly fighting the back pressure. It seems the output should go to a large diameter through-hull above the water line. A longer pump arm will probably help. I think one of my dock mates explained it best when he said "There is no better bilge pump than a scared sailor with a five gallon bucket". Does anyone know why the cockpit drains go to holes in the bottom of the boat instead of the sides ?
