Manual Bilge Pump
4
Hunter 336 woodbridge
Hi,
Just purchased a hunter 336 and am a bit lost finding the manual bilge pump, any ideas?
Jasdip5
Jun 6, 2006
6,990
It is in pieces
It should be near the helm. You will have just a hole that the handle fits in. the handle SHOULD be in one of the lockers EASILY accessible from the helm. It looks like a SS tube with a ball on the end.
If you can poke around in the lockers you should see the plumbing for it. Large diameter (1.5") hoses.
Benny
Sep 27, 2008
1,149
Hunter 320 Tampa, FL
The pump itself rests behind a rear panel in the aft stateroom. It may not be a bad idea to inspect it as we found out 8 years after the fact that ours had been damaged during installation at the factory.
