Hi Walt/ Judy
I think I found the Handle will try it in morning.
On the hard right now replacing engine with another MD6 ,installing roller furling system and bottom painting
Hope the handle works contacted last owners and they help by describing it.
a short aluminum tube with rubber hand grip on top.
Thanks for your advice will keep it in mind just in case .
Regards
Giani
SV/Pufffin #1554
walt/judy brown/allore bestvega@... wrote:Giani, I think veneers should be verniers (a type of caliper). You might try
wood dowels to determine the fit. PVC size refers to the inside diameter so
3/4" ID has a larger outside diameter and if it won't fit in the pump hole
start with a wooden dowel larger than 3/4". Save the receipt and return the
dowels when you're through. Somewhere near you there is somebody who deals
in scrap metal. Find them and ask to look through their stainless scrap.
You will probably find what you are looking for. You will pay for it by
weight when buying scrap. Get a piece a bit longet than you think you will
need. Longer gives more leverage but your arm will need to move more.
Shorter means less arm movement. You decide on whats comfortable for you.
Our handle is stored om metal clips next to the pump. We tether it to the
boat with a piece of dacron cord and roll the cord onto the handle to store
the excess.
Walt, Lyric #120
