Manual bildge pump replacement
Sep 23, 2009
1,475
Anyone ever replace their manual bildge pump?
What brands/models fit or don't fit?
Hate to drill more holes in the cockpit.
Mar 20, 2012
3,983
if you want to be sure of a direct fit without drilling more holes, replace the existing unit with an identical unit... or rebuild the one you got for a LOT less money...
if you want a bigger pump, you will have to accept you will need to drill a bigger pattern for the attaching hardware...
Aug 20, 2010
1,399
Oday 27 Oak Orchard
You can also consider attaching a backing plate using the existing holes and attach whatever pump you want to it.
