Manual anyone?
2
C&C 24 Trailer at home
I need a manual for a C&C 24. I am getting the boat ready for the water, purchased it and just got it down to Georgia. Apparently someone changed the mast, as the mast with the boat has 2 lower shrouds on each side, and there is nowhere on the deck to hook up 2 shrouds on each side. Also, the electrical plug on the mast opnly has 2 wires, ane there is a 4 wire plug coming from the cabin...that is the problem. I can't figure out why there are 4 wires (white, blue, green, and yellow) The white one is broken, below the deck, and I can't get at it to splice/ replace the white, which I assuming is the one I need to hook up for the mast light. Looking back at the fuse panel, I can't find hide or hair of the yellow, green, or blue wires, so I can't use them instead of the white.
Oct 29, 2008
134
Montgomery 17 Dothan, Al
Sounds like you need to do your best to trace the other colored wires and find out where they go.
Not sure why there are 4 wires coming from the cabin, but if you just have an anchor light you don't need but two. Sounds like you just need to get a new plug, both male and female, with the amount of wires you need and re-run them to the electrical panel.
Jul 8, 2012
144
Helms 25 indiana
I had the same problem with my boat. just have to trace each wire to its respected function and run fresh. works great now but still have a few more to deal with.
Apr 22, 2012
13
C&C C&C 24' Metedeconk River
manual
I own a C&C 24' I am a newbie so I don't have much experience to share but I purchased the manual from C&C owners if your still looking I will be happy to email you a copy
Lemme know
Nancy:)
