Mantus 35lb too big for Hunter 34 in the Chesapeake?
Dec 30, 2022
2
hunter 34 Chesapeake Bay
I seem to be between the 25lb and 35lb. "Assuming" either fits on my bow roller (i'll change it if needbe), and I like to sleep well, has anyone put a Mantus 35lb on a 34' 12,000lbs sailboat, ? or is that too much of an overkill since Mantus's are reported to hold so much better than plows/bruce's/etc of the same specs?
thanks
May 25, 2012
4,338
mantus recommends a 25lbs. weight above the waterline is a concern of those that also consider their sailing performance. many don't care.
Likes: ggrizzard
I upsized for my h356 to, I think, 35 lbs. The Hunter with it's high freeboard sails around on its anchor quite a bit. And when it reached the end of the yaw it would snap up quite hard. That was with an all chain or nearly all chain rode. A good snubber might have helped. Nevertheless, I think the extra size was better. For bigger races the anchor sat on the bottom of my slip.
Likes: stevefisher99
Sep 24, 2021
386
We used a Mantus 35 pounder on our 11,000 pound 34 footer - without a windlass (40 ft 5/16 chain plus rope rode). It was a comfort, if occasionally a bit much to lift. Although I'd think in the Chessy you won't be in 60 feet of water very often.
:plus: Good decision
Nov 28, 2016
103
Hunter 36 Northeast, MD
now i have yet another thing on my list to check in the spring - new 2008 Hunter 36, no idea of the size of the anchor on the bow ;)
Of the fun of getting a new to you boat.
Dress her up with lots of bling. Like a new girl friend.
