N
Nauti-Dawg
I don't believe my system was installed correctly. This is what I have, a Jabsco electric toilet that flows to a 6 gallon holding tank that has a 5/8" vent, a 1 1/2" outlet that has a hose going to a tee with the top side going to the deck for a pump out and the other side going to a seacock in the bottom of the hull (18" Draft). There is no vented loop, Y valve, or macerator pump to empty the tank when offshore. I have not owned this boat long enough to know if this system works, however the tank is only holding about an inch of water and the seacock is in the open position, which I know is not right, somy question is what is the proper configuration is there a drawing somewhere that I can view, should I have a pump will it be capable of pumping out the bottom of the hull with a 18" draft, and where can I get a bigger thru hull vent than the 5/8" that is there now. Also the toilet leaks around the base any Idea how to fix this. Sorry about the long post just wanted to include as much detail as possible --------------------------------------------------------------------------------Nauti-Dawg20'CC KeyWest W/ Merc 175Mako 243 W Twin Suzki 175's --------------------------------------------------------------------------------Edited by - Nauti-Dawg on Jan 03 2007 18:41:21
