Making Room
Dick
I'd read on this site about raising the table to make more room. It was easy. Table had been reduced in size by previous owner to make more room, but I wish he had left it as is so it could still be used as a berth. All that you need to do is raise the table as high as it will go. Mark the position in the base where the pin nests. Use a center punch and drill a 1/2 inch hole in the pole being careful not to damage CB line. Don't drill all the way through the base, but drill from each side. I used a 3/8th PTO pin I found in a tractor supply store. Raising the table makes it easier to get to the area in the bow besides making the seating area roomier.
