S sitkatm82 . Jun 12, 2010 17 Oct 15, 2010 #1 I am getting fuel in my oil, about a qt. in 4 hrs running. Any ideas? Engine is MD6 Frank
P pjacobs55 . Oct 30, 2019 1,459 Oct 15, 2010 #2 Does the MD6 have a mechanical fuel pump? This could be a source of fuel leaking into the oil sump. Peter #1331 'Sin Tacha'
S stevebirch2002 . Nov 8, 2001 1,818 Oct 15, 2010 #3 Hi Frank Most likely cause is the meachanical lift pump or more likely the seal in the high pressure injector pump. Cheers Steve B
