Installed inside track
I installed 4 foot tracks on the decking inside the toe rails. I lined up the track so that the forward part is heading towards the standing rigging. The rear of the rails is a couple inches from the cabin side. If I were to do it again, I would install 2 foot tracks. There were many holes to drill through the deck, and that was the hard part. Since the liner doesn't drop down on the H33, I drilled through the deck and the liner. I found that there was a space between the liner and the underside of the decking in many places, ranging from an inch or so to nothing. I used SS hardware with large washers for backing. In order to get the washers and lock-nuts through the holes in the liner, I had to bore those holes to the size of the washers. I also had to watch out for the bulkhead location between the head and the small berth on the starboard side. The port side I had to worry about the storage areas above the stove. I screwed everything down with good coating of silicon to bed the rails. If you want to do the job right, you should drill the holes larger than the hardware, fill with thickened epoxy, and re-drill the holes to the hardware size. This will keep any water from getting into the wood sandwiched between the fiberglass.I have 2-year old North sails, a new 2X2 main, and a 150% radial cut roller furling genoa.This racing season I took a couple second places flags and a third place flag. Do I point better? YES!I didn't take any pictures, and the boat is covered up for the season. I will try to remember to take some photos next spring and post the here on HOW.Ken Palmer, S/V Libertyhttp://www/LakeOntarioSailing.com
