Mainstay tension
F
Fred
I have recently purchaced a 1987 Hunter 23. The Mainstays seemed to be loose when the boat is rigged. Thew former owner said that that is the way they should be. But I didn't think there should be slack in the stays. Is there any way to determine the corect tension on the forestay and mainstays?
rickito
Turnbuckle use
I just think you should tighten the turnbuckles so the mast is supported firmly, of course the leeward stay will be loose when beating to windward, but I wouldn't have the mast able to move around, even a smiggeon by having the stays loose. Anyways, they will work themselves looser, faster if not tightened firmly. I've sailed small boats all my life, and I want that mast supported with a slight firmness to the stays.
Jun 2, 2004
425
- - Sandusky Harbor Marina, Lake Erie
Leeward stays should never be loose
If a stay of loose at all, the mast will shift in a tack or gybe to take up the looseness. The resulting shock loading of the stays (which can easily be a multiple of the steady state load) can lead to catastrophic failure of the rig. David Lady Lillie
Jun 3, 2004
232
Never Loose!
David is right on. You don't want your shrouds and stays loose! Purchase a Loos Tension Gauge. I have a model 90B that cost about $45 or $50 and comes with complete instructions. The best money I ever spent on my h23. Check your wire gauge and follow the chart on the back of the tension gauge. You need 10% of the maximum the wire can handle on the lower shrouds and 15% on the uppers. Mine is on the boat or I'd look at it for you. I believe the lower shrouds are at about 350 lbs. and the uppers around 500 lbs. of tension. I believe the forestay and backstay each have about 400 lbs of tension on them. She handles very well with a little weather helm, as you would like it to be. The leeward shrouds are never slack.
