Mainsheet
Aug 15, 2022
180
Catalina 22 14790 Redwood City, CA
Hello, Can anyone provide a photo of their main sheet orientation. I've been trying a few different configurations but I get a lot of resistance on it compared to boats I've had in the past. Appreciate any help I can get. Thank you
Feb 28, 2022
213
Catalina 22 12482 Champaign-Urbana, IL
See if either of these help. If not, dig through my album in my signature. I'm sure I have more photos in there. I try to add all my photos from the boat to this album.
Sep 14, 2014
1,287
Catalina 22 Pensacola, Florida
2 from catalina 22.org files and catalina direct catalog pages
Aug 15, 2022
180
Thank you that is how mine is as well. Its odd that you have to do an up motion with the cleat as I find it catches by itself quite frequently and my boom does not swing out as freely as some of my prior sailboats, just feels like there is a lot of friction in place. Everything is new on my end, so ill study it a little more to see what I can find. thanks for the pics.
Mar 20, 2015
3,298
C&C 30 Mk1 Winnipeg
That cleat angle is designed to be adjustable.The cleat angle moves in relation to the block. Likely just need to loosen the bolt and adjust it.
On @brockangelo mainsheet block it has a bolt that can go through multiple holes.
Yeah you pull the line upwards when cleating it.
Aug 15, 2022
180
That makes sense, I’m heading up tot he boat today I’ll see what I can do to loosen the mail sheet block. Thank you
Sep 23, 2021
29
Catalina 22 Davis Island Yacht Club
Rich Fox has a good solution to this in the 2017 C22 Tech Manual that involves attaching the mainsheet to the traveler with a cable effectively raising the block and the mainsheet cleat He used a 2 foot cable and a second line to support the block from the backstay to keep is from falling when running downwind. . You can decide what length works best for you.
There's also a double-ended mainsheet approach shown on Stingy Sailor's site.
And you do a combination of the two.
Aug 15, 2022
180
Awesome I will look into those, might be exactly what I need. Thanks
Mar 26, 2011
3,870
Corsair F-24 MK I Deale, MD
3:1 purchase is puney. A 420 dinghy is 3:1. Any Hobie cat runs 6:1 purchase, and many upgrade to 8:1. I run 8:1 on my F-24.
Yes, angle the cleat up until you can release it from any position in the cockpit--a safety basic, often overlooked.
Aug 15, 2022
180
Not sure how I missed this adjustable pin before. Put it in the forward hole and the clear angles up a lot better. I’ll still look at those options mentioned above.
