Mainsheet and Travler
Don Bollmeier
I wish to add a bimini. Can anyone recommend a travler / mainsheet configuration which will allow mainsheet clearance.
Don
C25 Bimini
Last spring I installed a bimini on my C25, but I did not change the stock mainsheet/traveller setup. It might not be worthwhile to move the traveller because the backstay will still obstruct the bimini(unless you have cutouts in the top) and if you or the next owner of your boat is planning to do any class racing, changing the mainsheet/traveller setup is illegal. Click on the related link to a discussion on biminis(including pictures) on the Sailor's Forum at the C25/C250 National Association website. Also, in the Tech Tips section you will find a cabintop traveller system that one owner installed. Once you get to the Sailor's Forum at the C25/C250 National Association, do a search on "Bimini" and you should get a lot of hits.
